So far, I've avoided installing any of the CE versions though I am tempted to do so to see how it compares to V8i possible to replace it however, I have noticed from this forum that there many posts about problems with it so I'm beginning to wonder just how bad is it? Looking to hear opinions from those who use it each day.
Unknown said: Depending on what you normally do inside MS, you can add greater functionality ie Items Reports Tables Display Rules Parametric modelling 2d and 3d Sheet Indexing Print Organizer Explorer DWG 2017 support
You know what Ian I don't use any of those tools listed. Did try them as part of the EAP but found no real benefit, as some we just wouldn't use, some need more work before becoming useful and some we can't use ans we don't work with worksets.
