I found how to reduce the collinear vertices in a polygon by accident a while back, just copy move parallel positive and repeat but same distance negative to reinstate the polygon in its original position, you can even use a reference file and copy into the active to prove it does retum in its original location.. I don't think its deliberate but rather a quirk that has a real benefit once you know about.... don't know if this works in CE...
Much more efficient than delete vertex one at a time see my example below
Hi Lorys,
This works the same in CE.
As a side note you don't need to copy parallel two times. With a single parallel (distance = 0) you'll get the desired result.
José
Unknown said: Hi Lorys, This works the same in CE. As a side note you don't need to copy parallel two times. With a single parallel (distance = 0) you'll get the desired result. Regards
Lorys
