When I have previously installed new versions or upgrades of Microstation, at least when installing on a new computer, I have had to get and install a Pre-requisite pack with the Microstation program. When I have looked for a download of Version 08.11.09.829 I have not seen a pre-requisite pack offered.
Is it not necessary now or can I use an earlier version of the pre-requites which I have on DVD, or how do I get the files?
As Jan and I have advised previously, all of the Prerequisites are downloaded and installed to your system via your internet connection if they are required. This is explained in the Requirements section of the ReadMe documentation under Software Prerequisites.
C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\MicroStation\readme_MicroStation.chm
Microsoft .NET Framework 4.5.1Microsoft XML Parser (MSXML) 6 SP 1 (32-bit and 64-bit)Microsoft Visual Basic for Applications coreMicrosoft Visual Basic for Applications localizedDHTML Editing Control for ApplicationsMicrosoft Internet Explorer v8.0 or later with 128-bit cipher strength is also required. It is not part of the Prerequisites for Bentley Desktop Applications.Copyrights in all components are owned by Microsoft Corporation or one of its affiliates, subsidiaries, or licensors.
We were only explaining to your that as this installation may not contain ALL of the prerequisites, as only those that are required will be downloaded, you could produce a Deployment Image. This Deployment Image procedure ensures that ALL of the necessary files required by an installation would be downloaded and made available for ANY system in the future to install MicroStation without an internet connection. This was in reply to your request to have ALL of these files if you decide to drop SELECT and be able to reinstall of a future system.
Hi Philip,
the situations you described sounds strange to me, I guess because of some confusions and mistakes in your assumptions and conclusions. In my opinion you are mixing apples and pears:
There is nothing like MicroStation with / without Deployment Guide. You can create Deployment Image, which contains both MicroStation installation files and Prerequisities files. More precisely, the term "Deployment Guide" is generally used for a document describing how to install (deploy) some software. So such document exists for MicroStation, but it's not the discussed topic.
I am not sure why you use "access to Bentley download" condition. It's not relevant at all. It's your choice (and also your responsibility) to decide whether you will store your own copy if MicroStation installer or not. In a hypothetical future, if you will own a valid license but will not have an access to download pages, you can still ask Bentley to provide you the installation for the owned version of MicroStation. This your decision has no relationship whether you will use standard MicroStation installation (withou prerequisities inside) or full deployment image.
The whole discussion is about two installation options:
With regards,
Jan
