Microstation Version 08.11.09.829 Pre-requisites.
When I have previously installed new versions or upgrades of Microstation, at least when installing on a new computer, I have had to get and install a Pre-requisite pack with  the Microstation program. When I have looked for a download of Version 08.11.09.829 I have not seen a pre-requisite pack offered.
Is it not necessary now or can I use an earlier version of the pre-requites which I have on DVD, or how do I get the files?
  • Hello again Andrew.
    To add to my previous reply to you, what I would like if it's possible is a disk or usb stick with Prerequisites on it and a disc or stick with Microstation on it for a version of Microstation V8i that will run on Windows 10, which I understand is Version 08.11.09.829 - so that I can load another pc if this one has to be replaced before I retire.
    Regards Phil Leach.
  • I'm sorry Andrew.
    I sent a second reply to your first answer before I realised you had answered my reply. Would a Deployment Image of all the Prerequisites have all the prerequisite files I would need when I don't have Select access, and would it be obvious how to create it using the Download button on the first reply you sent me?
    Regards and thanks Phil Leach.
  • As Jan Slegr advised already, Bentley do not supply a separate Prerequisite Pack for MicroStation V8i any more, as we did with previous versions. What you need to do is either install MicroStation V8i SS4 which should automatically download the prerequisites during the installation or create a Deployment image which would also download the prerequisites. If you are having an issue downloading these prerequisites you would need to ensure you are on a PC that can connect ok
    Andrew Bell
    Technical Support
    Bentley Systems
    If you install MicroStation V8i (SELECTseries 4) and have a good internet connection with no issues, the pre and post requisites that are required will be downloaded to your local drive. Usually, this would be in the folder:
    C:\BentleyDownloads\MicroStation_08.11.09.829
    Here you should see a full list of the MSI files used during the installation. This does not necessarily have every prerequisite as many of the specific Microsoft items would have already been installed.
    Whether you read through the Deployment Guide from the link I already provided or that which is available in the ReadMe file supplied with the downloaded software, you can see instructions for creating this image with all Pre and Post Requisites.
    Andrew Bell
    Technical Support
    Bentley Systems
    Answer Verified By: Philip Leach
  • Hi Philip,
    As Andrew wrote, Bentley does not provide Prerequisite Pack separately now, so it's not possible to have an installation of Prerequisities only. But I have see no reason to have it, because when you will create Deployment image, you will have one complete installation (Prerequisities + MicroStation), which I think is better.
    I am not quite sure if I understand what you are asking for :-( ... Maybe something lost in translation as I am not native English speaker.
    From the page mentioned by Andrew you can download Deployment Guide pdf document with the description how to create the Deplyyment Image.
    Based on what I remember, the whole process is pretty simple (just choose the deployment option in the installer), but not very intuitive, because it looks like the installation is run, but the image is created only. I am quite sure it's faster to try it (start MicroStation installation and try to create the image) than to write this text ;-)
    With regards,
       Jan
