Sheet files not displaying level overrides and sequences set in both Reference and Master Reference files
We are having issues with the level overrides and reference sequences in our sheet dgns. Essentially our sheet is set up with two references. The first reference is for our profile and does not have any nesting (our profile graphics are actually active in this file). The second reference is a master reference file for our plan view and does have nesting set to a depth of one. This reference file does not have any active graphics, in this file we are actually referencing our multiple plan view files into a single reference. Our goal was to make level override and sequencing changes in the master reference file so that we wouldn't have to go into ever single sheet to make those changes. We are running into issues though where the level override changes we make in the master reference file aren't showing up in the sheet dgn. Or some of the overrides are showing up but not all of them. We are even having this same problem with the regular profile reference that has no nesting. The one work around we have found is that if we detach and reattach the reference, the overrides are showing up as we expect. This work around is annoying and takes time though. Is there some workspace preference we need to have set for the references to update the overrides correctly without having to detach and reattach them?
