MicroStation V8i SS4, ProjectWise Environment
I am trying to create a named expression that is comparing specific letters noted in a named expression and in the _DGNFILE variable or the active file name to populate a menu item. I need to use the out of the box config var since I am in ProjectWise and I do not want the application to restart everytime I open a file.
What I have is always resulting in a False and I am not understanding why considering I thought I had the expression correct.
The file name is "01-CDM-PublishDevelopment-001.dgn". Here is what I have so far....
System.String.Compare(System.String.SubString(ConfigVar.GetExpandedConfigVar("_DGNFILE"),4,3),"CDM")
I want it to see tha the file I have open has CDM in this specific spot in the file name and then report back True and then show a specific set of tools based on that file name. Any ideas to do this with out of the box configuration vars is much appreciated however I would really prefer to use _DGNFILE to resolve the expression.
Thanks!
Mark W.
Unknown said:System.String.Compare(System.String.SubString(ConfigVar.GetExpandedConfigVar("_DGNFILE"),4,3),"CDM")
For testing, what happens if you substitute the literal file name instead of the config. variable?
System.String.Compare(System.String.SubString("01-CDM-PublishDevelopment-001.dgn",4,3),"CDM")
same result
The indexes are zero-based, e.g. the first character is at index zero. So I'm thinking your SubString should be (string, 3, 3).
Should work as you had it but with the start index of 3. It returns True for me.
