I have a problem with units. When I try to insert Active Angle Value, Microstation rounding units into unity. I can't change it in Settings - Design File. My workmates got the same problem. We are using PRT V8i. Does Anybody had the same problem?
Unknown said:We are using PRT V8i
Please identify the version of MicroStation, or other product such as PowerDraft, that you are using: MicroStation CONNECT or MicroStation V8i. What is the 8-digit version number (e.g. 10.xx.yy.zz) of MicroStation?
Unknown said: I changed in Computer Control Panel decimal separator from , to .
So this is an issue with the locale of your computer? What language pack do you have for MicroStation and Power Rail Track?
Little confused whether your issue is related to the Accuracy or Separator for the angle readout.
If it relating to the Accuracy setting for the Angle Readout then I would suggest looking at the Design File Settings.
