I need to use this version for compatibility with an older project.
Unknown said:Where can I download Select Series 3?
I would suggest the Fulfillment Center, but I don't see SS3 there.
Hi Betsy,
Only the last 2 Editions/Series (Connect, V8i) are available in the Fulfilment Center. It is always recommended to use the latest version in the series. Will “MicroStation V8i (English) 32-bit Version 08.11.09.829” not work with your older project.
Download linkselect.bentley.com/.../LTEyMzE5NjgyOTdfNC4wLjIuMA;ProductKeywords=MicroStation+CONNECT+Edition&KeywordProductId=&LanguageId=98&PackageTypeId=155&CurrentEventId=116#
If you still require the older version, please log a Service Request and mention the exact version and we will provide you a link.
Regards,Leonard Jones.
