OpenRoads Designer Bugs for the Point Control tool
Firstly, when the Corridor Objects tool is open, and click the Point Control tab, this program will not get responded immediately, then Microsoft .Net Framework error appears. See the following pictures, specially this error will always show after clicking the Point Control tab.
************** 异常文本 **************
System.NullReferenceException: 未将对象引用设置到对象的实例。
程序集版本:1.0.0.0
Win32 版本:09.10.02.30
基本代码:file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.Platform.DLL
Secondly, when using the Point Control tool to connect line 2 with line 1, the Triangulation error of Point Control area is fond, see the following picture. The curved surface is weird, and the template line is not perpendicular to its base line.
But with Power Inroads, it is perfectly right, nothing wrong with Triangulation of Point Control area, and template line is perpendicular to its base line.
So, hope you develop team can test the above bugs and kill them ASAP,and PLEASE  DO NOT LET YOUR CLIENT WAIT TOO LONG, SPECIFICALLY IN CHINA.
I have been using ORD since 2 months ago, but many bugs make ORD too difficult to use.
AS you may know, there are so many bugs, even some are fatal, I wonder whether you company start to kill this bugs, and wonder when the next version will be issued?
