Hi
Using Microstation connect U5.
If i create a .txt file with many ( a few thousen ) x,y,z coordinates, and every coordinate should have a different text ( a combination of numbers and letters ( Something like this; 1:Coordinate; x100 y200 z150 text= 1bar. 2:Coordinate; x300 y200 z250 text= 12bar etc... ) Would that be possible to import in to Microstation, maybe using the XYZ tool? If so how would i set this up to make it work?
Not very well explained, but i simply want to import data from another software ( CFD simulations ). In excel i have all XYZ the coordinates and i have the text for each XYZ coordinate. Im just not sure if there is a way to get this in to microstation without programming?
Helge
Unknown said:1:Coordinate; x100 y200 z150 text= 1bar. 2:Coordinate; x300 y200 z250 text= 12bar
I don't think that MicroStation's Text XYZ tool can interpret that format. However, it's a relatively simple matter to write a VBA macro to work with that format.
Can you provide a sample file?
Unknown said:CFD simulations
What tool do you use for CFD simulation?
Unknown said: There's no need for a VBA macro, only a bit of brain to get the right sequence of steps
There's no need for MicroStation either. You can draw all your maps on a large sheet of vellum with a quill pen.
Unknown said:You can't do it in one go, you'll have to create two or three Excel files and import them one after another, i. e. place a cell where the value has to go to and then the values themselves as text
If the OP has to import text many times, then your procedure is tedious and prone to human error.
Unknown said: I'll have to check again how I did it
A VBA macro is a formal record of 'how I did it'.
In other words, a VBA macro automates repetitive steps, saves time, eliminates human fallibility and doesn't require a bit of anyone's brain.
Hi Jon and fmandoki !Im using a CFD tool that our company develops ( and sell). Im using it as a consultant for explotions and fire simulations. Its called FLACS ( www.gexcon.com).So what i am trying to do is to take the results from the CFD simulation and show the values/ results inside microstation. To be more specific, this is monitor points in 3D space that shows some data. It could be pressure, it could be heat-loads or many other things .
Its not completely true that i have all the data in excel yet, but i think we easily can output something like the attached ASC testfile ( Ill confirm this with my coworker tomorrow and update this thread. We can probably also change this around, depending on what will work best with microstation. ). And from there take it in to excel if needed. What i am thinking is that i need a point and the text for each xyz coordinate. The point is just for showing the exact position of the coordinate. As i mentioned one of these files could have thousands of monitor points.
I would be interested to hear from both of you how i could do this. Im thinking that in the long run this is something that i defiantly would like to automate, but for now i would probably have to do it more manually.
t-007.zip
Hi Helge,
You can import text with coordinate values in several different arrangements. (TXYZ, TYXZ, XYZT, and YXZT)
The format of the text file you plan to import should be as follows:
(Replace the X Y and Z with the actual coordinate values and replace $ with Text (Limit of 10 characters))
For the example file you provided you should just replace the spaces with commas to seperate the fields and use the XYZT order as shown below.
12,47,8,10Bar8,52,8,130.4Bar9,52,8,10Bar10,52,8,160Bar8,53,8,17.5Bar9,53,8,17.3Bar9,43,9,152.1Bar10,43,9,152.6Bar8,44,9,7Bar9,44,9,120Bar10,44,9,172Bar11,44,9,102Bar9,45,9,152Bar10,45,9,125Bar11,45,9,162Bar12,45,9,12Bar9,46,9,12Bar10,46,9,12Bar11,46,9,162Bar12,46,9,12Bar13,46,9,125Bar
HTH,Ron
Answer Verified By: helgeh
