We use the Microstation V8i Command Window (MS_USECOMMANDWINDOW) for typing commands.
We could turn it on under Workspace/Configuration/Operation/Use Command Window & set the value to 1.
Has this been eliminated in Microstation Connect?
Unknown said:We use the Microstation V8i Command Window
You mean the key-in window?
Look at the MicroStation CONNECT ribbon menu. Top-right is a search tool. Start typing a command in that tool to see matches...
Press your Enter key to activate the selected tool.
No not the Key-in. It is the "Command Window".
Timothy Hickman
Main: 877 627 3772|
Answer Verified By: Dave Haw
