I've imported some customized linestyles from a rsc-file to a dgnlib file. Is there a way to list what is in my dgnlib-file? How do I delete one or more of the linestyles, which I no longer want to be in my dgnlib-file?
Thank you!
LiPeng of Denmark
Depending on the version of MicroStation being used.
CONNECT Edition :
To view the line styles open the dgnlib file and the 'Explorer', then expand the 'Explorer' tree to see the Line styles
V8i : To see what Line styles are in the dgnlib, open the *.dgnlib and select Element > Linestyles > Custom, to open the Line Styles dialogSelect a name without brackets () and it will show the path and name of the file its coming from below.
Alternatively you could export the line styles from the dgnlib to a new *.rsc file using the Line Style Editor dialog select File > Export From DGN.Once exported open this *.rsc in the Line Style Editor, File > Open and view/edit/delete the line styles.
Edited line styles in the *.rsc can then be imported back into the dgnlib (or into a new one ) by selecting File > Import > rsc. If the styles already exist in the opened dgnlib it is possible to overwrite those line styles with the same name should you wish to do so. Note this may have adverse affects to other users who need or have used these line style(s).
An Enhancement Request 117911 is filed requesting the ability to edit / modify custom linestyles in the dgnlib
Carl Myhill
Technical Support Engineer
Bentley Systems
Answer Verified By: LiPeng
you could open the dgnlib file and use this key in
delete unused linestyles [name]
change [name] to the name of the linestyle you want removed from the dgnlib
Answer Verified By: Nick Alteri
Where is the File Tab under the explorer tab? I am using Open Roads Connect Edition - and I don't have that as an option = only Items, OpenRoads Model, Standard, etc,
go to the backstage and select settings then Explorer Settings. Make sure the visible under the file section is set to yes
