Microstation Connect Edition Update 5 Installation setup using /layout
Hello, trying to create a deployment installation using the /layout switch and the created package does not follow the answer file that is created. There was a similar problem with update 2 or 3 that was fixed with the following update but now it appears to be broke again.
Any ideas on what I can check or if anyone else is having similar issues? Everything downloads without issue. If i just unzip it and run the install manually then it installs fine.
I have read and followed the other post with the instructions and get the same results. I even followed the naming scheme in the instructions.
RB
