Hi All
I have received a lot of geometry that has lots and lots of shapes, each shape has several hundred vertices. (This comes from the application it was created in NOT MS) I need to remove the vertices, but how? I do not want to do this one by one.
V8i & CE5
Thank you
Ian
In all CE editions you can recreate shapes automatically and the end result is without middle vertices - the main difference for V8i.
In V8i:
https://communities.bentley.com/products/microstation/w/microstation__wiki/22208/remove-collinear-points-or-vertices
I would like to add that with this you can achieve the same in one less step, no need to copy, you can move and distance equal 0.
José
Answer Verified By: Ian Lapper
Jose
Nice one. CE bring it on......
