line still displays after break command
I am new to Microstation, so maybe I just don't know how the BREAK command works.
I can break a complex element (created from Horizontal Geometry - Complex by PI) successfully. But when I hover over the complex element, the full length of the orginal element is displayed. If I select the element, I see the entire original length. Is this normal? Why does Microstation display the original element?
  • When you break the line are you breaking it and deleting a portion of the line or are you just breaking it at a specific point and leaving the entire length the same? If you are breaking the original element into 2 pieces and not deleting anything I would suspect that you have the Graphic Group Lock on. This would explain the behavior of highlighting & selecting both elements. Turn off the Graphic Group Lock <Settings <Locks <Graphic Group
    Microstation CONNECT - 10.17.2.61
    ORD - 2021 R1 10.10.1.3
    ORD 2022 R1.1 - 10.11.3.2
    ORD 2022 R3 -  10.12.2.4
    ProjectWise - 10.0.3.453
  • yes, the graphic group lock was on. I turned it off and I am still get the same results. I am breaking the line to remove a segment in the middle. Break works fine on a regular line or a smart line. I only have this problem when I break an alignment.
    Dale
    Civil 3D 2018, ORD 2019 Rel 1, InRoads SS3
    Drug kicking and screaming into the world of InRoads & ORD!!
  • Unknown said:
    I only have this problem when I break an alignment [in Power InRoads]
    Well, I don't use that product, but my guess is that the alignment may be a cell or other complex element.
    You might want to post your question to the appropriate forum.
    Regards, Jon Summers
    LA Solutions
  • If you have your alignment file loaded in Power InRoads then the entire alignment will most likely highlight since you are only breaking the alignment graphically. If you redisplay the alignment using Power InRoads the segment you deleted will reappear. You did not break the alignment into 2 separate alignments so Power InRoads still recognizes it as one continuous line. Try using Horizontal Tracking and you will see that the tracking will still follow the same path and report stationing in the gap you created.
  • mwlong, thanks for the reply. Unfortunately the tracking does not follow the path. The tracking stops when I get to the gap and resumes when I get to the other segment. The alignment was created using SS3 commands, not from the InRoads Explorer (SS2).
    In the Project Explorer, under Line Elements, it list all 3 elements. They are named test (original alignment), test 1 (first segment of the break), and test 2 (second segment of the break)
    ps - I started a thread in the InRoads forum but wanted to reply to this.
    Dale
  • Ok, that must be based on the OpenRoads Technology then. I have not had much of a chance to work on that platform. I'm sure someone on the other forum can help.
Reply Children
