line still displays after break command
I am new to Microstation, so maybe I just don't know how the BREAK command works.
I can break a complex element (created from Horizontal Geometry - Complex by PI) successfully. But when I hover over the complex element, the full length of the orginal element is displayed. If I select the element, I see the entire original length. Is this normal? Why does Microstation display the original element?
  • If you have your alignment file loaded in Power InRoads then the entire alignment will most likely highlight since you are only breaking the alignment graphically. If you redisplay the alignment using Power InRoads the segment you deleted will reappear. You did not break the alignment into 2 separate alignments so Power InRoads still recognizes it as one continuous line. Try using Horizontal Tracking and you will see that the tracking will still follow the same path and report stationing in the gap you created.
    Microstation CONNECT - 10.17.2.61
    ORD - 2021 R1 10.10.1.3
    ORD 2022 R1.1 - 10.11.3.2
    ORD 2022 R3 -  10.12.2.4
    ProjectWise - 10.0.3.453
  • This isn't a Microstation issue - it's is specific to the modification of a Horizontal Alignment created by Power InRoads. Mwlong has the right answer for this situation.
    If you try that command on a plain Microstation element (not created by InRoads) you should see that it behaves as expected.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • mwlong, thanks for the reply. Unfortunately the tracking does not follow the path. The tracking stops when I get to the gap and resumes when I get to the other segment. The alignment was created using SS3 commands, not from the InRoads Explorer (SS2).
    In the Project Explorer, under Line Elements, it list all 3 elements. They are named test (original alignment), test 1 (first segment of the break), and test 2 (second segment of the break)
    ps - I started a thread in the InRoads forum but wanted to reply to this.
    Dale
    Civil 3D 2018, ORD 2019 Rel 1, InRoads SS3
    Drug kicking and screaming into the world of InRoads & ORD!!
  • Ok, that must be based on the OpenRoads Technology then. I have not had much of a chance to work on that platform. I'm sure someone on the other forum can help.
