I went to downloed the CEU6 install file, and all i found was a small install executable that then downloaded the install file and installed it.
Will there be a full install file so I don't have to use the executable every time I update a computer ?
Michael.
Unknown said:Will there be a full install file?
The announcement tells us how to obtain a full installation file.
You may have a look at this thread:
https://communities.bentley.com/products/microstation/f/microstation-forum/139477/ce-update-6
As mentioned by Jon, the steps needed to download the full installation of MicroStation CONNECT Edition x64 (Full) Update 6 from the Fulfillment Center, can be found here:
https://communities.bentley.com/products/microstation/f/microstation-announcements-forum/139454/microstation-connect-edition-update-6
Derval Canny.
Hi Michael,
Creating a local Deployment Image is the method to adopt, this saves time on every install, especially when you choose the Passive UI Mode which pre-sets all of the installation dialogs. It copies all of the installation files required by your installation choices to a specified local network location so subsequent installs are not using valuable internet bandwidth.
Marc
All
I have just created the deployment in CE6 and I can confirm it is now working. In previous builds it wasn't. Just need PowerDraft CE6 to follow suit ASAP
Ian
