Dot terminator size
Has Bentley deliberately avoided this 'enhancement' just to annoy users?
The word processor has to be the worst feature of the programme. Too many options and not enough simple functionality for users.
The dot terminator size will not / can not be adjusted in size. The arrow terminator scale is fine, but how can I adjust the size of this minute circle? I know that it is related to text height and width units but there is no change in size despite adjusting the numbers.
This should really be a simple process, but I just cannot get the scale to increase to a size that is legible.
Please help......
  • Open the Text Style editor dialog and go to the Geometry tab. In the Terminators section change the Width & Height values to adjust the Dot terminator. Make sure you do not change an existing style using the arrowhead terminator as it will change the size of those as well.
    Microstation CONNECT - 10.17.2.61
    ORD - 2021 R1 10.10.1.3
    ORD 2022 R1.1 - 10.11.3.2
    ORD 2022 R3 -  10.12.2.4
    ProjectWise - 10.0.3.453
  • Thanks for the response.
    I was eventually able to get this terminator to increase to a reasonable size - whether or not this was by luck or design, I cannot say. The dimension settings dialog box really is over-complicated - and not only that there are TWO different dialogs - one of which is almost useless.
    There really needs to be a separate dialog for adjusting terminators - it makes absolutely no sense having to use the 'arrow' terminator height and width to adjust the 'dot' terminator.
    I also use AECOsim and MicroStation, and not the InRoads software.
Reply
