CE Sheet Index - Sheet names
Hi
I have a great deal of clients that over a vast period of time have created Sheets models with the name of the Paper size ie A1 Sheet.  This was great but now that we have sheet indexing, this is a right pain.  The Sheet index import tool will only show the sheet model names and not the dgn filename.  Thus, I have hundreds of indexed sheets all called A1 Sheet , A3 Sheet etc.  Next to useless.
Thus when we add sheets to the index we need to be able to change the index name ie use the dgn filename.
Ian
  • Wouldn't it be really nice if you could edit the sheet name in the Index, and push those changes back to the design files?
    We're light years away from using Connect anything, but the Index sounds like something I'd like to play with whenever we do get around to it. I can foresee issues with the way we do things here...Often sheets are copied from one to the other to the other, and not everyone (myself included) always takes the extra time to change all the sheet names along the way. We end up with a bunch of "Plan" sheets, and a bunch of erosion control sheets called "Plan" and a bunch of pavement marking sheets called 'Plan" - you can see where this goes. The file names are all different, which helps some, but sheet/model names would be most easier to tailor to some useful description. While Index sounds like a nifty little option, it's not going to do us much good without a solid naming structure under our belts. Some kind of single location to list and edit our sheets would be very helpful, but that doesn't appear to be part of the Index function.
    I tried playing with this sort of thing in VBA a while back, and quickly got in over my head (I'm not even sure it is possible to have that kind of interactive dialog working on a range of files).
    Or am I confused and reading too much into the (potential of the) Index function?
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • Mary
    You are right.
    If you do not name your sheet correctly with a full name. Sadly sheet indexing is a waste of time and effort.  See below
    These are 3 sheets I have managed to index, it automatically added 001, 2 and 3.  Nothing to do with the actual file name. I cannot see the original name from the index.
    Below is a typical sheet file naming convention.  Other users will vary........ but I believe Bentley users all follow a similar process
    This is what should be displayed in the index.........
    Thus if a user saw this, they would close it and NEVER use it again.
Reply
  • Mary
    You are right.
