<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>What happened to TFREMOVE?  What can I do.</title><link>https://communities.bentley.com/products/microstation/f/microstation-forum/139853/what-happened-to-tfremove-what-can-i-do</link><description>We haven&amp;#39;t used Trifroma in 5 or 6 years. I have some old model files that I get the standard &amp;quot;Trifroma has intentionally restricted the changes to this element&amp;quot; In the past we have been able to use the TFREMOVE command in V8i and it would remove the</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: What happened to TFREMOVE?  What can I do.</title><link>https://communities.bentley.com/thread/423534?ContentTypeID=1</link><pubDate>Thu, 17 Aug 2017 01:20:13 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:dff0e292-a8a2-4af4-9aff-7c00a3f89745</guid><dc:creator>Andrew Bell</dc:creator><description>&lt;p&gt;SR # 7000669785&lt;/p&gt;
&lt;p&gt;The TFREMOVE keyin is only available if you also have either the old Triforma extension or one of the old Structural or Building products. If you no longer have access to any of these products there are a number of suggestion to possibly make these elements available to edit.&lt;/p&gt;
&lt;ul&gt;
&lt;li&gt;Select&amp;nbsp;all these elements and use the Drop Element tool while ticking the Application Elements option&lt;/li&gt;
&lt;li&gt;Convert your DGN file to DWG and back to DGN as this can eliminate any Triforma elements&lt;/li&gt;
&lt;li&gt;Upgrade to the AECOsim Building Designer software which includes this keyin&lt;/li&gt;
&lt;/ul&gt;
&lt;p&gt;&lt;a href="/products/building/building_analysis___design/f/aecosim-speedikon-forum/60635/triforma-is-locking-files/146373#146373"&gt;https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forum/60635/triforma-is-locking-files/146373#146373&lt;/a&gt;&lt;/p&gt;
&lt;p&gt;&lt;a href="/products/building/building_analysis___design/f/aecosim-speedikon-forum/67521/dgn-files-with-elements-locked-by-triforma/174315#174315"&gt;https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forum/67521/dgn-files-with-elements-locked-by-triforma/174315#174315&lt;/a&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: What happened to TFREMOVE?  What can I do.</title><link>https://communities.bentley.com/thread/423533?ContentTypeID=1</link><pubDate>Thu, 17 Aug 2017 00:35:17 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:e46f4608-03e5-4f2b-a480-0610c082d905</guid><dc:creator>David Trejo-Rodriguez</dc:creator><description>&lt;p&gt;The TFREMOVE keyin is not available in MicroStation but is part of AECOsim Building Designer&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
