How to create item type?
thanks
Hi
Can you explain a little bit more what you are trying to achieve. Also can you let us know what version of MS you are using ie 08.11.09.459 (see help about for this
Ian
as Ian wrote, it's not clear what msi8 means, such MicroStation version does not exist. I assume you mean MicroStation V8i ... but there are about 7 versions of V8i, so "V8i" only is still not precise enough specification.
Item Type is MicroStation CONNECT Edition feature and cannot be created in older MicroStation versions. There is a backward compatibility implemented in terms of accessing item type values, when they exist in DGN file already. But MicroStation V8i does not offer tools to modify existing item type structure or to create new ones. You also cannot attach item types to elements.
So if you want to work with Item Types, you have to use MicroStation CONNECT Edition.
With regards,
Jan
If you are a select user, you can learn how to create item types in MicroStation CONNECT Edition from the LEARNserver : Item Types
For more information on new features in MicroStation CONNECT: https://communities.bentley.com/products/microstation/w/microstation__wiki/31320/list-of-what-s-new-and-changed-in-microstation-connect-edition
Aim
Thanks for everyone.
There are ITEM sets in v8i but they are not the same thing in CE , in V8i they don't have metadata, they are more like a display set or view group, the only way in V8i that you can make the sort of thing, though more limited in v8i like the Items in CE but using V8i is to use Tags and attach those tags to elements..the tag then can have an excel like table attached but its single column and multi row but the same names for row and column are assigned per tag set... and the individual fields or records can be prepopulated by default or not and also by hand ie edit the tag for each element, you can also create reports to extract data for tagged elements programatically as element have properties like level name , colour, type of element , area, length, perimeter etc and with some vision or planning can be used to give useful reports about things like room areas, number of and type of doors or windows, signage schedules , part lists for Bill of materials etc...
I posted here many times a tutorial ( not created by me but Karen Fugle one very smart lady) on tags and creating reports on tags search for tags 101 should find it.. if your not going over to CE and cant find the tutorial PM me and I'll send pdf and link to video I did for the local users meeting ages ago...
here is the link to the post you'll need to scroll down to find the 101 tags.txt link , down loads it and rename extension to pdf so you can view it... lots of other good stuff in that post even the video link whch still works and stuff on programs to import export tags so you can do Title block updates in both directions ie export for cad to excel or other and import back into lots of title blocks new data ie revisions , dates etc...
I use this stuff all the time for entire project plan sets and for drawing indexes or registers to keep track of revs too as well as part lists etc ...
https://communities.bentley.com/products/microstation/f/microstation-forum/76432/tags-to-excel/306395#306395
Lorys
