HOW TO ROTATE TEXT OR ELEMENT TO ANOTHER ELEMENT V8I
Ive been trying to do this  for ages  an it was driving me  nuts... too many  steps with accudraw to go wrong, found a few clues in old posts and  filled in the blanks
keyin ROTATE VIEW ELEMENT; %d;%d;ACTIVE ANGLE PT2
( THE ABOVE COULD BE SET TO AN F KY  IF YOU USE IT ALOT)
You'll be  prompted t select an element ( text or line or shape) to set the  view rotation
Then you'll need to Tentatative twice on the reference  line element ( the  one you want to rotate to) one end first and then the other end last
now you active angle is the angle of the reference  line
next  we click on the rotate icon and it has the new angle set, so now click on the text or element you want rotated
now key in vi=top to return the view ot original state and our text or line as adopted the angle of the reference element line...
I tried to make another  keyin
rotate icon;%d;vi=top
but it works like this select the text to rotate, data point in the view and  reset button mouse. then it rotates the text to right angle and sets view back to normal but doesnt
work if you use your  mouse buttons in any other order it fails to do what you want  cant work out why  but works.. other wise the rotate bit can view top can just be done by hand  or icons etc
Autocad has all this  much easier R for rotate  and option is reference so r and  two clicks and  done...
I wish we had a simple tool or  macro with two clicks...
