HOW TO ROTATE TEXT OR ELEMENT TO ANOTHER ELEMENT V8I
Ive been trying to do this  for ages  an it was driving me  nuts... too many  steps with accudraw to go wrong, found a few clues in old posts and  filled in the blanks
keyin ROTATE VIEW ELEMENT; %d;%d;ACTIVE ANGLE PT2
( THE ABOVE COULD BE SET TO AN F KY  IF YOU USE IT ALOT)
You'll be  prompted t select an element ( text or line or shape) to set the  view rotation
Then you'll need to Tentatative twice on the reference  line element ( the  one you want to rotate to) one end first and then the other end last
now you active angle is the angle of the reference  line
next  we click on the rotate icon and it has the new angle set, so now click on the text or element you want rotated
now key in vi=top to return the view ot original state and our text or line as adopted the angle of the reference element line...
I tried to make another  keyin
rotate icon;%d;vi=top
but it works like this select the text to rotate, data point in the view and  reset button mouse. then it rotates the text to right angle and sets view back to normal but doesnt
work if you use your  mouse buttons in any other order it fails to do what you want  cant work out why  but works.. other wise the rotate bit can view top can just be done by hand  or icons etc
Autocad has all this  much easier R for rotate  and option is reference so r and  two clicks and  done...
I wish we had a simple tool or  macro with two clicks...
  • My problem is I have a  rotated view in model with title block ref attached, then I have match lines which should be perpendicular to the chainage ( or stationing line or design line)  and some times I need to re rotate the  tag text that is  supposed to be  in line  with the  match lines.. often the designes rework things and the match lines need to be adjusted / re rotated  .. so when I examine a  line that is perpendicular to the design line it does give me the angle i need.. but when I click on the tag text  in the properties it wont let me  change the text angle.. I have had the angle assistant but I must be using it  wrong or the rotated view and tag text is  complicating it.. or I need to relearn angle assistant  from Inga... in a place  I worked many   years ago we used xm and had a great little custom tool that was added to our tool bar and  fkeys  and only  needed two clicks    1st click to get the desired angle then 2nd click on element to change  rotation and it  just rotated even in rotated views .. I miss its simplicity...... btw  how do we reply with quotes from user  posts
    Lorys
    click link to PM me
    Select the text in the post that you want to quote and a little box with "Quote" appears. Press it afterwards and the text is copied to your reply.
    I'm all for VBA but I only use it for really complex operations, this task seems pretty simple going by your description. I do similar operations frequently and only ever use the rotate command with accudraw but to each their own.
    Not sure what goes wrong for you. Care to upload an example file with target element (to rotate to) and source element (to be rotated) and I can show the steps how I approach it?
  • I don't really work with tags so I don't know if the rotation operates different from regular text.
    When I want to rotate text to an element I have Accudraw eneabled. Then I select Rotate Element by 3 points and select the text at it's origin then I switch the snap to nearest and select the end of the text (if the text is placed with Top Left justification I select that point first, switching to nearest snap I would select what would be the Top Right justification point for the second point). The rotation point is anchored at the first snap point and Accudraw Compass will be anchored there also. I make sure Accudraw has focus (my F10 fkey is programmed for Accudraw focus) and I hit RE and slect the element for rotation (this rotates Accudraw compass to the selected element) then allow the Accudraw indexing for the proper rotation and data point to place the text rotated to the element. So 4 clicks and it's done.
    Microstation CONNECT 10.17.00.209
    ORD CONNECT 2021 R1 10.10.1.3
    Microstation v8i SS 10 08.11.09.919
    Power InRoads v8i 08.11.09.615
    ProjectWise 10.0.3.453
  •  I
    have it too but it doesnt  work for me  with tag text  ...accudraw has even more steps to make it work then just rotate 3 points by eye... its too bad angle assistant doesnt  work with tag text .. I know works on lines ,cells and plain text...Attached simple example of what I have
    Lorys
    click link to PM me
  • But you can use Accudraw to rotate text to align with elements. I do it all the time: select text, pick the rotate command, pick the text center, then use perpendicular snap to upper or lower "text box/line" and then rotate perpendicular to element to be aligned with. I put that all in shortkeys so it's not much of a hassle if you have only a few texts to align.
