after connected my access database(ACCESS 2016), execute the query in Visual SQL Query Builder, the ERROR form always jump out.
it caused by the ACCESS 2016? Because the HELP said the supported database is ACCESS 2010 and 2013.
AND I changed the setting
the change would cause the problem?
thanks
with regards
zhu
This could possibly be related to the compatibility of a MS Access 2016 database. As you say the documentation for MicroStation CONNECT Edition only has support for:
https://docs.bentley.com/LiveContent/content/en/MicroStation%20Help-v8/GUID-B2EA3622-A80A-D2B6-E295-7EB857BEC214
Does it make any difference if you toggle off Dataset Mode in the VSQL dialog?
no difference.
and I try it on 2 computers( with win7 or win10), there are the same problem.
THE DATBASE IS BENTLY SAMPLE DATABASE. I GUESS I miss something when I installed the CE.
OH, MY GOG。
