CONNECT selection set with reference lost after operation.
Odd minor issue here, but I've notice when I make a selection set that includes a reference file that is set to be manipulated as an element and then perform an operation on that selection set (move or rotate for example) after I complete the operation and hit the reset button the selection set is lost. The really odd thing is this only happens when I have the Models dialogue open.  In the video here I make a selection set of a title block and other elements and move it. It acts as expected and retains the selection set after I hit reset allowing me to perform a new operation on the selection set. When I open the Models dialogue and do the same thing the selection set is lost after the move operation which means I need to reselect everything to perform another operation. It's a minor issue, but something I found that doesn't work as expected. It only seems to be a problem with the reference selected.
