In AutoCAD we have a LISP routine which lists all the attached references in bottom left corner of the layout (also rotated 90 degrees).
Is it possible to do this in Microstation? Our current project demands it and it would be a hassle to update this by hand.
Thanks!
In MicroStation V8i (you didn't say what version you are using), you can go into the Reference dialog, Highlight (Select) the list of attached references, Do a Ctrl+C and then go to the Place Text and Paste (Ctrl+V) into the Text Editor, and place the list as Text in the file. To update you just delete the existing list and place a new list. Takes all of 30 sec.
The ability exists of writing a VBA that will do what you want.
You might be able to do what you want using new features in Connect.
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
You may find the following posts helpful:
https://communities.bentley.com/products/microstation/f/z_-archived-microstation-v8-2004-edition-forum/76235/reference-files-list
https://communities.bentley.com/products/microstation/f/microstation-forum/139501/automated-list-of-x-refs-in-drawing-sheet/422554#422554
