Hi. Short and to the point: in Microstation V8i, is there a way to turn off the Primary Class elements similar to the way you can turn off Construction Class elements in the View Attributes Tool?
Thank you!
The following will temporarily hide all of the non-construction elements.
Thank you so much Ron!
Answer Verified By: Stephanie Masonbrink
am i not seeing it because of the version i use?
Apologies - i think i've found the command (is it displayset?)
Andy Foulds said:am i not seeing it ...?
What do you see in MicroStation (as opposed to what you see in help)? The right-click menus are context-sensitive.
Andy Foulds said:... because of the version i use?
We can't answer that unless you tell us what version you are using.
