I have multiple lines made by simple line (not linestrings) and i need to adjust these lines on correct position. I'm not allowed to merge the lines into linestrings. Also there can be duplicates lines but different layers.
So is there any way to drag the commune vertices for all lines?
We have center lines that represents towers for power lines.
As i said we can have multiple lines on top of each other (for different voltage)
Each lines has a few informations like label, number of cables,etc
If we merge them we lose all that info. but we need to move them together on the exact tower position.
10000-15000 lines, all from the same exact point to another same exact point?
MaryB
A picture is worth a thousand words
Can you show a couple of screenshots of what you are trying to achieve, it might help you get a solution quicker.
and a closer look
As you can see the lines are not on the right position, so we need to be able to move all vertices at the same time
Are you using MicroStation CONNECT or MicroStation V8i? Is this plain old MicroStation, or are you using an additional app. for your industry?
From your screenshot I guess you're using MicroStation CONNECT with some Item Types that you, or some application, have defined?
