Hello everyone,
I need a good computer to work with MicroStation.
I would like to hear you recommendations about the most important I should look for in the computer in order to take the most of MicroStation.
Should I look for a good Processor or a good Ram and what are the best in your opinion.
Many thanks for all your help.
Hi Luis,please see the following info regarding minimum hardware requirements for MicroStation CONNECT Edition:https://communities.bentley.com/products/microstation/w/microstation__wiki/23674/microstation-connect-edition-frequently-asked-questions
https://communities.bentley.com/products/microstation/w/microstation__wiki/24799/microstation-connect-edition-system-requirements
Best regards,Andrea
