When doing a "SAVE AS" I want to be able to direct which folder to save in. I use Accudraw shortcuts and want to add a command to the shortcut key-in that opens a specific folder instead of having to search each time.
If your always going to do it to a specific folder, then I know you can add a script to an f key to the save as command and it will wait for you to name the file... but not sure how to d it for accudraw keyins,,, lots of f key combos available or even make custom button on your company interface... but I love F keys if you look up my past posts F keys Rule man!
Lorys
Hi Dave,
In my opinion it's not possible, I vaguely remember it was discussed in the past several times.
I guess all file operation dialogs remember last used path plus folders defined by MicroStation configuration variables.
To make folder navigation less annoying, you can use:
With regards,
Jan
