Line Scaling
Green at Microstatoin (Autodesk background).  We have a files provided by a client. When I reference one of the files into our file the line scaling is off. I compared our file against a provided file that shares the same reference as ours here is what I found: The Drawing Scales are identical, with annotation scaling on. I checked the Model Properties and Line Style Scale is set to Annotation Scale for both. Both are 2D Design files. The reference file in question are attached in both drawings with Scale Line by Reference Scale and Use Active Annotation Scale. If I set the reference Presentations the same I still have the issue. View attributes are similar with the exception of Fill and Level Overrides are turn on in our dgn file. I know I’m missing something but cannot find what this is.
PowerGeopak SS4 v08.11.09.878
  • Mary, thanks for the reply.  Should have mentioned in my original post I had tried what you suggested without success.
  • Yea Bob, I am referring to the Line Style Scale setting, in the Model Properties dialog.
    It could also be a scale factor for the Level By-Level setting, or the Override settings (if used) for the level.
    Make sure both files are looking at the same Custom Line Style definition, Same rsc file for that Line Style definition. You could be looking at a Line Style definition that has been written to the active file, or is in a DgnLib, or in a Resource (.rsc) and the definitions can be different for the same Custom Line Style name. To see where it is is drawing the definition from, go to the Settings > Line Styles > Custom. In that dialog, go to the Line Style in the list, and just above the preview display, it will tell where the Definition is stored.
    I Hope This Helps Someone Reading This!  (Intergraph>PseudoStation>MicroStation user since 1980's)
  • George, thank you for the information. I had checked the Model Properties and the Line Style Scales were identical.
    It appears our dgn and the clients both store the line definition from the dgn. Seems strange since the definition should be provided by our DOT, and I would have thought they were the same. The project was converted from SS2 to SS4 so maybe that’s why. Is there a way to update my dgn to use the same line definition?
  • Did you check the linestyle scale on the level from the reference attachment (also mentioned by George)? This one is easy to miss by someone with primarily ACAD background, due to lack of the concept in that world. Open up "Level Manager", right mouse button select the level you need to check, bring up "Properties" dialog box, then go to "Styles" tab. There are two linestyle scale overrides from level, one for ByLevel and the other for Level Overrides.  You mentioned that you had Level Overrides turned on in your view, so that's the one you need to check.
  • Don, for the information.  I had looked at this but the levels are "greyed" out and do not allow me to make changes.  As a background to the file, we have a dgn file the references various other dgn files.  That file used to control the appearance of the files.  This in turn is referenced into Sheet files.  I ended up using the base dgn provided us and setup the referenced in that file they way the should appear.  The line style scales are correct per our client in that file.  It is the sheet files they are incorrect in, and I cannot modify the properties there.  FYI, I did try to use our seed file to create the controlling file but the linetype scales were incorrect in that file.  That is why I used the clients file as the "seed" file instead.  Hopefully that makes sense.
    I'm going to attempt to export, then import the RSC file to see if that works.
