I did a clip volume section in Microstation 3D. I can see two different colors, green lines at top and bottom and pink shaded area (see attached sketch). What is this colors stands for? Where can I found the settings of these?
Here is a similar situation to yours, with a step by step layout of how to solve it. Hope this helps!
https://communities.bentley.com/products/microstation/w/microstation__wiki/14528/cannot-modify-clip-volume
This page explains the display of clip volume of handles only.
Unknown said:pink shaded area
Pink shaded is the highlight default that you get when the cursor is over the object.
When the cursor is outside you can see the real aspect of the section - your left picture.
Unknown said:What is this colors stands for?
Green color is very likely to be from Forward display style - Edge settings\Visible Edges - green color override.
Unknown said:Where can I found the settings of these?
You can edit this settings using CTRL+B to open the View Attributes and then Clip Volume Settings\Cut - Display Styles\Cut and others like Forward:
José
