I would think if a $99 cad program can do this that Bentley implement this. Draftsight cad. www.draftsight2017.com/split-dimension.html
I believe this discussion has been mentioned a number of times to implement a capability to break or split dimension leaders.
https://communities.bentley.com/products/microstation/f/microstation-forum/21103/break-dimension-leader-lines/52281#52281
There appears to be a few Enhancement Requests raised to perform different types of break / split / jog operations when it comes to dimensions.
Enhancement 41208 - As a user I would like to be able to define a symbol that makes a dimension line appear jogged or broken and have it appear as part of the dimension element.
Enhancement 41215 - As a user I would like to be able to break a dimension element without dropping the dimension element.
Enhancement 86149 (old TR 302305) - When you add a dimension to an element and have the Extension line enabled and/or Terminators you are not able to break this extension/terminator in case the dimension text crosses with another text or dimension. User would like that this was a possibility, at the moment you have to drop the dimension and manual move around.
These enhancement will be evaluated by Bentley product management team for inclusion in future release of MicroStation
