It there a keyin I can use to select Notes?
I can use PowerSelector keyins to almost create a selection of all text elements. Text, text nodes and dimensions are available. However, notes are not available so I cant select notes text as well. Is there any other keyin or macro that might be available to also select notes, or to select all text elements?
  • Jovan, hello!
    I am trying to get more clarity on the use of the key-in, as I am stuck with couple roadblocks trying to select particular textnode with particular text in there ( yes, it gets very narrow in my case, as I need to select only one of several texnodes, ont the same level, with the same text formatting and color etc.)
    so, my command currently is the following:
    MDL LOAD SELECTBY
    SELECTBY MODE INCLUSIVE
    SELECTBY OPTIONS SELECTION
    SELECTBY ON
    SELECTBY LEVEL NONE
    SELECTBY LEVEL G-ANNO-TITL
    SELECTBY TYPE TEXTNODE
    SELECTBY EXECUTE
    currently I am stuck with the level selection, as it does not select specific level;
    another issue I am having is selection of the text with the wildcard ( I need all the drawings of AXXX series, so text wildcard would look like "A*"
    Thank you !
  • Try this VBA macro
    Sub SelectNoteElements()
        Dim oElement As Element
        Dim oEnumerator As ElementEnumerator
        Set oEnumerator = ActiveModelReference.Scan
        ActiveModelReference.UnselectAllElements
        Do While oEnumerator.MoveNext
            Set oElement = oEnumerator.Current
            Dim ph As PropertyHandler
            Set ph = CreatePropertyHandler(oElement)
            If (True = ph.SelectByAccessString("Description")) Then
                If (ph.GetValue = "Note") Then
                    'Debug.Print ph.GetValue + " - "; oElement.Type
                    ActiveModelReference.SelectElement oElement
                End If
            End If
        Loop
    End Sub
