I am currently trying to customize the drawingseed.dgnlid to suit our company standards. I have followed the procedures given in the design drawing and sheet composition tuturiol on the learn server but seem to get stuck creating a drawing from a callout. Have followed all the procedures in the tuturiol from setting up new seed files, amending the config file, and creating a new drawingseed.dgnlib using the 3dMetric Seed delivered with microstation I end up with the create drawing and sheet section grey out see below.
I am not sure were i have gone wrong?any ideas
Using Microstation Connect Update 6 on windows 10
1. Click on MicroStation and “Run as administrator.
2. Click “New file” icon besides Bentley logo.
3. Assign any “File name” and click “Browse” (Seed)
4. Select seed2d or seed3d as required and hit “Open”.
5. “Save” the newly created drawing/design file.
6. “Open” the new drawing/design file.
7. Click on the “Design File” under “Settings” pulldown menu.
8. Set all the parameters as required through “Design File Settings” dialog box shown below.
9. Click “Save As” under “File” pulldown menu.
10. Save it under your seed file directory.
11. Create text file using note pad and enter the following:
# yourName.cfg - V8i Configuration File.
_USTN_USERDESCR = YourName
MS_SPELLINGLANGUAGE = AmericanEnglish
MS_DESIGNSEED = C:/Program Files (x86)/ (directory where the seed file is) /seed2d.dgn
12. Save “yourName.cfg” the text file into “C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\MicroStation\config\appl
13. Every time you create new drawing/design file, this will be the directory where you will select whatever seed files you created.
http://www.tubero.com/
