Microstation v8 Macro
Hello everybody, is there a macro so I can get the coordinates of the application points I throw on the MicroStation as a file?
  • Unknown said:
    Is there a macro so I can get the coordinates of the application points I throw on the MicroStation as a file?
    It's not clear what you are asking.
    Tell us what you want to do more clearly (get the coordinates of the application points I throw on the MicroStation as a file), perhaps with a DGN example  Then we can suggest ways to achieve your goal.  Those suggestions may, or may not, include a recommendation to develop a macro.
    Regards, Jon Summers
    LA Solutions
  • hi Mr. jon Summers.
    I can not tell you exactly because my english is not good.:( So I have a closed areas and broken lines.
    Is there a macro that outputs the corner coordinates of closed areas or broken lines in text format ?
    i hope i can tell :(
    Post a DGN file that contains the shape element or 'broken line element' that you want to analyse.
    LA Solutions
  • project.rar
    1   420173.19    4456862.53
    2   420169.13    4456802.66
    3   420167.17    4456773.82
    4   420157.75    4456696.69
    5   420148.33    4456619.56
    I have sent a dgn and a text file.
    How can I write the coordinates to the text file as I send the example
  • Hi Bahadir
    First edit your coordinates txt file with notepad and delete your first column with the ID points 1, 2, 3, 4 and 5.
    Then back in Microstation use CTRL+T to open tool Boxes and in the end you see: XYZ Text, check this one and click OK:
    Then use the last to Import Coordinates, browse for your file.
    Please note that the points created will be in your active level.
    https://communities.bentley.com/products/microstation/w/microstation__wiki/14762/how-to-input-coordinate-data-into-microstation
    José
    Answer Verified By: Bahadır MEMİŞ
  • Thank you so much Mr.Jose Pinho.I solved the problem your way.
Reply Children
