I recently added memory to my system and immediately my snap lock began acting up. I do not use AccuSnap. Whenever I tentatively snap on an element, the cursor sticks on that point until I use the reset button. Then, normally that would cancel the operation, but it just releases the tentative snap to allow me to snap elsewhere. I am not accustomed to that and I want to be able to cycle through tentative snaps without having to reset.
Is there a setting that controls that?
Usually if you keep hitting the tentative snap you should cycle through the various points then data point when you find the desired point. Not sure I follow
Unknown said:Then, normally that would cancel the operation, but it just releases the tentative snap to allow me to snap elsewhere.
It seems to be working as it always has.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Could you have multiple elements, one on top of another, that it is snapping too?
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
In the past, I could cycle through element choices for snap locations. I would not have to reset to do the cycling.
It is not that I have multiple elements. The tentative snap sticks to the first element that it locates.
And just using tentative snap again does not work. If I have several points close to each other and I use tentative snap a point is selected. If I hit tentative snap again it moves to the next point. I can keep doing that until I find the desired point. No reset in between.
