Hey Folks! Is there a way to search/find a level by its name in Microstation. For instance, I've got a long list of levels (300-400 levels), and I need to find a certain level name in the Level Manager or Level Display list. How can I do this very quick? Thanks in advance.
P.S. By entering first letter of the level while searching isn't handy in this case, since I've got a lot of levels that starts with the same letter.
Use the Level Filters! This tool will display only the levels that fit the criteria in the filter. You can filter the levels by Partial Name, Description, Number of elements, and much more, or just choose the levels you want to display in a Group. The filter works for the Level Manager, Level Display and List of levels shown in the Attributes dialog.
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
In addition, if working with CE Edition for a quick find use this on the fly on the ribbon\attributes:
If working with many levels it's better to use filters this way:
https://communities.bentley.com/communities/other_communities/askinga/w/askinga/434/group-your-levels-using-filters
José
I just started using this method in v8i. In the past I did not need to worry about finding a level because we have filters setup. I have been working a lot for our Virginia offices and I am not familiar with their levels and their filters to not eliminate enough levels. I am usually looking at a pdf of the levels with descriptions and I just type the level name into Level Manager as George states and the level is found. Once done I just clear that from the "on-the-fly" filter to see the other levels.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Many thanks for your replies guys. With your help/suggestions found the ideal solution for me. I've set up the 'List Filter' as 'All Levels' instead of '(none)'. This is allows to search any level by its criteria on the attributes ribbon of levels. So simple and so confused in the same time
Kind Regards,
Yaxo
