Hi all, is there a way to to set this: my view atribute windows keep opening in very large, it is taking all the screen. I tryed reducing it and close the dialog box but it keeps coming back the same size the nest time I open it. Any cue on where to search. Thanks
You should be able to move the cursor to the edge of the dialog and get a double arrow to resize this. If this is not saving the change when you perform a Save Settings and exit then it is most likely related to your permissions to save to the file or folder for your User Preference File. Check for the location of your UPF under > Workspace > About Workspace and ensure you have Read+Write permissions to this file. If this does not resolve your problem then you could always reset your User Preferences with the follow Wiki article.
https://communities.bentley.com/products/microstation/w/microstation__wiki/8978/how-to-reset-user-preferences-and-delete-microstation-s-temporary-files
Thanks for taking the time to reply, you were right it was a problem related to the workspace I was working on (or actualy the lack of workspace I was working on). I'm new to microstation and even if I can work with it, there is a lot of thing that I don't understand about how it work. How to setup workspace and what parameter it influence, how to use DGNLIB and what to put into them are just two examples. It just take a lot of time when you don't have nobody to show you how. If you have any tips for workspace and dgnlib (one of those don't miss that important information link page) if not thanks for your time.
Unknown said:There are a lot of things that I don't understand...
That's normal — but there are resources that may help you.
Depending on where you are in the world, you may find a local user group full of enthusiastic MicroStation experts.
Here are some Wiki links that you may find helpful from the MicroStation Community.
CONNECT Edition - Configuration: Customization Guides
Setting up the MicroStation CONNECT Workspace on a Network
Creating a DGNLIB Library File for Customizing MicroStation's User Interface
How to Customize V8i menus in CONNECT Edition?
As Jon Summers has also mentioned there are many great training courses available from the Bentley Institute:
Getting Started with MicroStation CONNECT Edition
Hope this helps.
Wow thanks for taking the time to send me thoses links, I'm not finished yet reading every thing, but still it look exactly like what I was missing. Thanks again both of you for your help.
