Dear Users,
I can not find any info how to split line ( in my case pipe) to several elements.
Shortcuts 6 -> 1 is not working. (drop element).
Any idea how to do it?
RegardsS
Break element is not solution.
Version of Microstation is not relevant.
We have V8i, SS2, SS3.
Line was mady by *.rsc format, so breaking elements will not working properly.
If I have line style -> it work (better or not), but if software don`t have my *.rsc is not working.
So any ideas how to solve it?
Thanks for Your helping ;)
S
Unknown said: Version of Microstation is not relevant. We have V8i, SS2, SS3.
Best answer ever! Element type is even more irrelevant.
I'll need to step away, mind reading is not working today. You folks go for it!
You do not understand me.We work on various versions of Bentley programs such as Microstation, Inroads, Powercivil etc.We also use different versions of programs : XM, V8i SS2, SS3.Neither method works in any of the programs / versions described.
So I write that there was not relevant.
We also try to use fences or any other ideas to split lines with this style, but none of the were helpful.
Any other metohods to spli lines (with this*.rsc style) ?
Partial Delete can be useful only if You have *.rsc file.
Even after break to (can we say) "separate" elements they are still using line style from beginnings.
When we change line style to another ( no metter how many element were created) it change line to new style (circle, line etc.) and all figure has been gone. ( if new style is continous line all "separate" elements are continous line ( old circle is change not to circle but line).
