Is it possible to use a length property in an item type to control a dimension in a graphic cell? What if the cell has multiple instances in a Model? I am working on a library of traffic signal cells and am trying to use one mast arm cell to cover all the necessary lengths (Say 20 ft to 70 ft). I can change the length of the mast arm through a constraint but i also need to change it in the item type data. If this linkage is possible, i would be great to see a video tutorial on it. The images showing the constrain and the item type are from the same element.
Jason
