I have a default setting for dimension geometry extension lies of -2.0
I have reset it to -.5, thousands of times, it seems.
How do I change it so it stays as I want it?
Are you working in a DGN file or DWG?
There are some issues regarding dimensions in DWG mode.
And there are some options dependent of your Microstation version.
If working in DGN file you should work in a DGNlib file where you store your dimensions. Unless it's a one time thing that you need only for a single drawing.
Did you save your new settings?
This could be related to your needs:
communities.bentley.com/.../why-does-the-dimension-line-position-change-when-i-modify-a-dimensions-extension-line
And here you can study dimensions more in detail:
communities.bentley.com/.../general---dimensions---microstation
José
I also like having a dgn that has all these unusual dim styles named in my docs folder and can just use the import dim style from that stored dgn file for one off occasions but for company stds we have a dgnlib with the named std dim styles and text styles...
Lorys
Yes I havent yet started storing dim styles in a dgnlib
when you say:
working in DGN file you should work in a DGNlib file,
I suppose that is the same relationship between DGN and DGNlib as
I use to manage my customised menu items.
