I have several elements in an elevation view which need to be placed on a sloping ground line.
The simple align elements by edge command will align them all to the lowest point on
the groundline, which is not what is wanted.
Is there a simple way to shift them all, with one command, so they rest properly
on the inclined groundplane?
Unknown said:sloping ground line
Is the line a simple line (two vertices) or a line string (more than two vertices)?
This can help you:
https://communities.bentley.com/products/microstation/w/microstation__wiki/16120/how-to-move-elements-to-different-z-elevation
You should always start your question title with the software and version.
https://communities.bentley.com/help/w/be_communities_help/4413/communities-forums-best-practices-and-tips
José
Jose thanks. I am drafting in 2D, uStn PwrDrft V8i (sel 3) V 8.11.09.397
I need to move many elements to different heights depending on their horizontal position, the height being determined
by a sloping ground. A command which sets them all to the same height is not what is needed. Thanks, Jimm
under the copy pallete is the "move to contact ", you can select all the elements to move with the control key then drag the mouse in the direction of the line to contact and data point to accept.. all the objects will move to strike the sloped line... make sure you line is long enough so when you drag your in the x or y axis to drag in other wise they move sideways relative to where they should be.. sounds tricky but is very easy .. do a few test tries first till you get the hang of it... make sure you read the prompts
Lorys
yes excellent thanks i never noticed that one. problem solved; thanks.
your welcome so how about some points or vote is helped me gotta keep my average up... haha
