How do you change the terminator for dimensions. I want to use a place not with a dot terminator. I see under the Geometry tab the Terminators section but am unsure how to change from Arrowhead to a filled Dot.
PowerGeopak SS4 v08.11.09.878
Go under the Text tab and then to the Notes section. There is a drop down for Terminators where you will find a filled dot.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Answer Verified By: Robert Watson
Thanks for the quick reply. Would you be able to tell me how to increase the size of the DOT?
Under the Geometry tab go to the Terminators section and change the Height value
Thanks again. Just found it and was going to reply. Probably should have researched a little before posting again. Thanks for the help.
