I need to clip out a portion of a "nested" reference file. I don't see the option.
version 8.11.09.832. Thanks for your help.
Eric
You need to go into the container file and apply your clip mask there.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
The main reason for using Live Nested references, is to give the display control over to the file that you are live nesting too. You can gain the control back, by changing the Live Nesting to Copy Attachments. This will make direct attachments of those Live Nested references, Then you can control (Clip Bound) them individually. Of course if the original file reclip bounds its' reference you would not see it.
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
If you copy the attachments to make them direct attachments then what is the purpose of Live Nesting in the first place other than a basis to start a sheet. This will only afford you the luxury of not having to select each file to reference individually. The Live Nesting allows you to apply all of your display settings to one file.
That's a good solution, please back up your file before you do this. Copy attachment vs nested reference may change appearance of your document.
I also find it very annoying that Microstation does not have this functionality. It is crucial for making plan sets where you want to control display with a container file, but also need to mask elements in the sheet.
