I'm sure this has come up but I couldn't find the answer.
Where is Select By Attributes equivalent in Connect Edition release 7?
I need to migrate from v8i to connect soon, so I'm trying to get comfortable with the newer software. In particular I like to use the Select By Attributes byElement command.
It's on the Home tab of the Ribbon, under "Selection":
You might find that this icon that Bruce has mentioned does not display by default. If you right click on this ribbon group you can choose the Selecy By Attributes to ensure it is being displayed here.
You may find the Search Ribbon tool in the top right corner of the application window of assistance in locating any tools you may be having problems locating.
https://communities.bentley.com/products/microstation/w/microstation__wiki/27894/how-to-easily-find-any-tool-in-microstation-connect-edition
Answer Verified By: Bob Rayner
You can also left-click in the status bar right next to the level name display and choose from "select element", "select all", "deselect all" and "select by attributes".
Here's a screenshot from the German version:
Apologies folks, I was in "Task Navigation" mode instead of "Drawing" (not even sure what that means). So I found the command where expected, but it still does not show up in the search window.
Unknown said:but it still does not show up in the search window.
It show if you do this way.
Type in Search Ribbon select and click in Show all results:
Even faster is to type in Search Ribbon the two letter word "by".
José
