How to get rid of "Incompatible version of AEC objects" It's slowing down our whole process when working wit MicroStation CE updt 7 and about 150 DWG drawings.
Please help
//Christiaan
No one on this?
If you need to work with this version of MicroStation CONNECT, then any changes you make to the file will break the AEC objects and they will no longer work with the software that created them. If this is the choice you want to make, then look at the second link Maria has provided, it should provide you with what you are looking for.
Timothy Hickman
Main: 877 627 3772|
ok - so we are past the message then ?
and now the issue is that CONNECT is slow when opening due to the DWG references ?
Yes,I can provide you the DGN file and the DWG reference so You can look at it?
I did a quick speed comparison between MS CE update 7 and MS SS3 and there is a huge difference.
MS CE Updt 7: 2:18 min
MS Ss3: 0:30 min
This is only for 10 Reference files and I have about 150 DWG files as a reference needed, so it’s almost impossible to work with L
I am getting this on ORD U7 and Microstation CE U12 using references that have come from AutoCAD 2018 and older. I installed the Civil 3d 2018 Object Enabler and it won't go away - anyone know what's happening?
I'm convinced this is causing some instability.
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
Still happening in Microstation CE Update 17.2 with the latest Object enablers
