How to get rid of "Incompatible version of AEC objects" It's slowing down our whole process when working wit MicroStation CE updt 7 and about 150 DWG drawings.
Please help
//Christiaan
I put an addendum on the article that shows the variable for CONNECT.
Timothy Hickman
Main: 877 627 3772|
Hi Tim,
That is a step. But I have a lot of Reference files in DWG format from other disciplines and I cant change. I reference these files into MicroStation CE and it very slow when opening the major file?
Any idea
ok - so we are past the message then ?
and now the issue is that CONNECT is slow when opening due to the DWG references ?
Yes,I can provide you the DGN file and the DWG reference so You can look at it?
I did a quick speed comparison between MS CE update 7 and MS SS3 and there is a huge difference.
MS CE Updt 7: 2:18 min
MS Ss3: 0:30 min
This is only for 10 Reference files and I have about 150 DWG files as a reference needed, so it’s almost impossible to work with L
