I am a fairly new user of Microstation Plant Design. I have used Microstations for about 2 years off and on and have never had this problem. When I try to dimension something the dimension dont show up. ( no dimensions, arrow heads , nothing)
Is not the level being on or off, for I can draw objects in the same location. Its not the position of the dimensions in 3Dspace. for I can draw objects and see them. Its not the section of the dimensions in the dialog box , for it is deselected.
Also I can open other drawings and have no problem putting dimensions on objects.
Thanks for your help in advance cliff
Clifton,
Check that View Attribute for Dimensions is enabled ( As you say above you have checked the Level was on,
View Attributes would be the next logical thing to check )
https://www.credly.com/badges/2671d5d0-32f7-4a42-8aa9-bd2864aa14c1/public_url
Hi Clifton
additionally please have a look at following wiki article:
https://communities.bentley.com/products/microstation/w/microstation__wiki/14206/new-dimensions-not-displayed
Andrea
Answer Verified By: clifton maggard
This was exactly what the problem was. I had inadvertently turned off level 50, which was the dimension level.
Thanks soooooo much
