i have a short question regarding digitizing lines automatically.
I need to draw some new area boundaries. As you see in the attachment,
i am digitizing a new red smartline with a specific level among an other sketch line.
I am using Akkusnap mode and i am trying to catch all vertex points. But it cost me to much time
to send every time a datapoint to catch all vertex points. Can i automatize it by VBA
or is there a better snap mode which would trace the sketch line automatically.
Tolga
You write that you're using MicroStation V8i, but does the toolbox labelled Topology Crea... belong to some other application?
Answer Verified By: Tolga T.
Thats Bentley Map or the legacy GeoGraphics product. Why don' you use "copy"?
Frank
